Available Metrics
Once you access Cadasio Analytics, you’ll see a range of data points that help you evaluate project performance. Let’s break down the key sections:
Overview
- Total Views – The number of times your projects have been opened.
- Average Engagement Time – The average duration a viewer spends interacting with your projects.
- Average Rating – The average feedback score submitted by users.
Project Breakdown
A detailed table lists all your published projects with individual metrics for each one. The table is ordered by total views by default, but you can adjust this by clicking the column headings. Pagination controls at the bottom help you navigate through your projects efficiently.
Engagement Trends
A graphical representation of total views helps identify trends over specific time periods. This data is useful for spotting peaks in engagement and understanding when users are most active.
Geographic Distribution
An interactive map displays the locations of users accessing your projects. Hovering over a country reveals detailed statistics, and a side list breaks down engagement by country.
Completion Rate
This metric shows the percentage of users who complete a project. By default, a project is considered complete if a viewer progresses through at least 80% of it, but this threshold can be adjusted using a slider. Changing the tolerance updates both the pie chart and completion values in the project table.
Device and Operating System Breakdown
- Operating Systems – A list of operating systems used to access projects.
- Devices – A breakdown of devices (e.g., desktop, tablet, mobile) to help you tailor content for different screen sizes.
User Feedback
A table displaying collected feedback, including ratings and comments, helps you gauge audience sentiment and identify areas for improvement.
Filtering Data for Better Insights
By default, Cadasio Analytics displays data from all published projects over the last six months. However, you can refine your analysis using the filtering options available.
Adjusting the Date Range
Use the dropdown menu to select a predefined date range or set a custom range. This allows you to focus on recent activity or compare performance over specific periods.
Filtering by Tags
If you use project tags, you can filter analytics to display only tagged projects. Tags help group similar projects together for more meaningful analysis.
Filtering by Specific Projects
You can narrow down analytics to individual projects using several methods:
- Autocomplete Search – Start typing a project name to quickly find and select it.
- Table Selection – Use the checkboxes next to project names and click the filter icon at the bottom.
Conclusion
Cadasio Analytics empowers you with the insights needed to refine your projects, improve engagement, and optimise user experience. By leveraging the available metrics and filtering options, you can make data-driven decisions to enhance your presentations.
For more tips on using Cadasio, follow us on your favourite social platforms and stay tuned for the latest updates!
